Low oil pressure on wot?
Mynlow pressure oil light comes on and the gauge goes all the way down when under hard acwleration. I already have t500 and the meiling lpop with stock injectors. Its has been happening just curious why this is going on, scaned it for hpop and thatsbwhen inbought thebt500. I dont drive much in my heavy tow tune so idk if it happens in that tune but even in my eco/light tow it goes on. Cruising is fine just not pedal to the metal situations
Is this because of the double shots? Or is it a tunning issue or something else? Truck runs great besides this egt non issue plenry of power very low smoke almost none with d2 in all outntune. I run wmo someetimes and it smokes with that but that is expected.
Oh and just forgot to mention it starts up great cold hot whatever, coldest day yet was 31 since i had the motor out and even with a 6speed now just beat a hemi(1500 pretty new looking) from 40-80 mph lol but my point is i think its running fantastic.
The oil level? Just changed it... its good. Like i said its been going on just never thought about it much figured it was tune since alot of the tunes out there say no low oil pressure codes. And never drove it much before i had it out. I read online most people have some driveability issues to go along with it. No codes present other than exhaust backpressure stuff since the ebpv is deleted. I think on my way home il drive in the heavy tow (near stock right?) And is have a manual gauge il put on tonight i was curious if anyone had this before. And i have a new lpop because infound out what happens when younput the stocker in wrong. New cover and everything
Ok i installed a manual gauge, when cold the oil pressure rises with load and rpm (by cold i meant it was running for 30nseconds) after 10 mins of idling the pressure would drop particular under a load. Idk what could make it loose pressure like that it couldnt be the screen it wouldnhave an issue especially when cold but when its warm is qhen the problem occurs. Im thinking injectors leaking internally? It did get better with the new t500 i never bothered withbit before because i was told its because of the tunes... but than i got to thinking that wasnt right. Cold it jump from 50-80 than hit rev limiter and drop to 60. When hot would idle 45 and just drop from there.
Pocket is driving at an uber-demand situation with a tune, and that's where my head first went - but my gut tells me this is something else. I've seen a lot of data on trucks with crazy demands from oil, which is extremely common... but the low oil pressure light is not common at all.
If a little too much debris made its way into the oil pan (aluminum seals for bottles), it can block the pickup screen, or your oil pickup tube seal may be failing, or your engine front cover may have too much clearance between it and the pump. None of these scenarios are a happy ending, because they all involve breaking the seal on the oil pan - and messing with the pan is usually an engine-lift thing. There is one likely candidate left that is nowhere near as bad as an engine lift - injector O-rings. I suggest searching the term "Cody test", and performing that action.
How far below 45 PSI do you go at idle? Given all the work to replace everything oil pump related, I'll go out on a limb and say this is your last gasp at solving a long-term problem. Oil type?
