Spark plug & coil questions
Replacement coils are available from Rockauto starting at around $12 each... You can always find a 5% discount code with a google search.
For that $38.33 each from AutoZone, you're getting a lifetime warranty so you're probably paying for several of them up front. While their store brand is usually decent enough, they are not Denso/Motorcraft parts that have been private-labeled for the chain.
Motorcraft Coils
We see a good number of the Escape PCMs come through our shop for ignition coil failure. It's a very common issue. Ford has come out with updated Motorcraft coils and plugs to help correct this issue. We recommend Motorcraft simply because our customers who replace with Motorcraft don't blow their PCM out a 2nd time. There are a ton of cheap coil options and even counterfeit Motorcraft coils. When buying, check out the link below regarding counterfeit coils -
https://circuitboardmedics.com/blog/...gnition-coils/
__________________
We specialize in repairing and rebuilding circuitry in automotive modules. By repairing these components, CBM offers customers an alternative to high cost replacement parts and a timely solution for malfunctioning vehicles.
Visit us at www.CircuitBoardMedics.com or call us at 800-547-2049.
