99 250 v10 has no power
10-16-2016, 08:16 PM
on
This my first post. I have a 99 f250 sd with v10 that has no power. Will crank, idle and die sometimes. Getting codes p0351 - p0355. No power when driving. Has anyone had this or similar problem? Thank you
10-16-2016, 09:11 PM
Welcome to FTE! Those codes are for a bad coil. Pretty common problem and an easy fix.
10-17-2016, 05:31 AM
Are you getting all 5 coil faults for bank 1? If so, you've either lost coil power to that side of the engine or the PCM has failed.
10-17-2016, 05:32 AM
on
Thank you for your response. Would all 5 have problems at the same time?
10-17-2016, 05:33 AM
on
Yes. I get code for all 5
10-17-2016, 05:39 AM
That could also be a vacuum leak on bank 1.
10-17-2016, 05:42 AM
on
Ok. Will check for that. Thank you
10-17-2016, 08:34 AM
Quote:
Originally Posted by
redford
No, it cannot. P035x codes indicate an
electrical problem. See PCED for circuit and code definitions.
Vacuum issues cannot cause this.
10-17-2016, 08:38 AM
on
10-17-2016, 10:58 AM
I just saw where you said code 351 through 355. I read it as 351 and 355.
10-17-2016, 11:40 AM
on
I should have been more clear in my explanation
01-28-2017, 08:22 PM
on
Took the truck to my mechanic and turned out to bad PCM. Put used one in. Ran but had skip. One coil bad. Thanks for the help
mattf76
1999 to 2016 Super Duty
02-07-2017 01:36 PM
lciambotti
12-29-2011 12:36 PM
bro460
11-17-2011 08:34 PM
Soodude
08-18-2011 10:46 PM
uh60
Modular V10 (6.8l)
24
12-30-2007 06:01 PM
