2017 SD trying to get out of using 5th wheel hitch
New truck 2 weeks away. 17 CCSB 6.7 and I don't want to lose what's left of my shortbed (after my auxiliary fuel tank) to a 5th wheel hitch. Looking at the Anderson conversion which will also move the trailer back 8" to help with the shortbed clearance issue to the front of the trailer. Anyone have any insight or experience with this hitch? My goal here is to convert my 5th wheel to Gooseneck style hitch and get out of the 5th wheel hitch altogether. Have heard it puts too much stress on the neck of the 5th wheel and will cause issues. My old SD sold with my Superglide hitch in it. Was a nice hitch but a pain to take out and put in so I left it in all the time which left me without any bed space. Anderson 3139 hitch conversion looks like just the ticket or fabricating one from scratch and just replace the whole pinbox. Any ideas?
Tried the towing forum but didn't get much of a response. Thanks in advance!
Both look like great products. Thank you. The Goosebox doesn't fix my need for an offset hitch point to solve the clearance issues with a short bed & the other style hitch leaves the hitch in the bed so it takes up much needed space while not using the 5th wheel. The Anderson 3139 looks like it would solve both issues but haven't found anyone who has used this product as of yet.
Go to RV forums and you will find tons of info. Here is just one from the Grand design forum:
http://www.granddesignowners.com/for...ersen+ultimate
Check this out guys. Might want to rethink the Anderson Hitch.
https://www.rv.net/forum/index.cfm/f...print/true.cfm
Have used the Andersen for two years now and would not give it up. Has worked perfectly and the company will support you for as long as you own it.
Attachment 162375
Attachment 162376
Also hangs on the wall for storage at 32 pounds.
Attachment 162375
Attachment 162376
This may be the better option for me I'm thinking rather than the adapter to Gooseneck that everyone is saying will crack the frame. Little worried about the deformity it caused on the one guys pinbox.
I ordered my 17 SD with gooseneck/5th wheel prep and the Gooseneck package. What options am I left with if I go with the traditional 5th wheel hitch that will use the Ford prep?
Also, on your Anderson does it latch in anywhere or just sit on the floor of the truck while attached to the original gooseneck ball?
I'm getting a long bed and seriously considering the Andersen Ultimate Aluminum. It saves 100# and is supposed to ride smoother. With a wimpy 3100# payload on a long-bed 4x4 6.7 platinum ultimate, I need to save every pound that I can.
Took a while but I knew that remark was coming. Don't care for the long bed on my personal truck, have enough of them in the fleet and frankly don't care for the look. To each their own on long vs short bed. My 5th wheel is the only trailer I tow that its an issue with so I'll deal with that on the 1 trailer in order to keep the short bed. Super glide on my previous truck but was a pain to take out. Thinking of trying the Andersen Ultimate after reading the feedback. Thanks again!
