Edelbrock?
10-16-2016, 04:31 PM
on
Edelbrock?
So i was given an Edelbrock carburetor. I am having hell finding out if it will fit my 73' F100 302. I rebuilt it, and im trying to find a throttle adaption that fits my throttle lever but all im seeming to find is throttle cable adaptions. Its a 1405 carb. can it even fit my truck?
10-16-2016, 05:01 PM
You got an auto or manual trans?
10-16-2016, 10:15 PM
on
10-16-2016, 10:18 PM
Not sure what kick down you have .... here is a 1405 on a 351M with C-6.
10-16-2016, 10:25 PM
on
Yeah see thats not at all like mine that has a cable for the throttle mine is a metal rod. And the kickdown is alot like that one
10-19-2016, 11:29 PM
Quote:
Originally Posted by
Harley Hill
Look again ..... mine has a rod for throttle ..... that chain thingy is a cable for the Sears Cruise Control I put on in the '80s which still works.
10-20-2016, 09:24 PM
I used a Ford throttle kit from Edelbrock but i had to modify my kick down rod slightly, but my rod was from a c4 and i am using with a c6....that may have been part of why i had to modify. I also use the factory rod throttle linkage. Mine is also a 460 that went where 302 used to live....so that may have caused more differences. You should be able to make it work.
10-21-2016, 02:57 PM
on
Ok I see yeah I think I can make it work. I have my carb all built and ready to put in. I'm just waiting on a spacer. Thanks guys
10-21-2016, 07:06 PM
Holley makes a kick down rod extention for when you are instally a 4V carb where there was a 2V. Part number 20-41.
10-21-2016, 08:20 PM
Yep .... 4V moves primaries forwards .... I made mine many many years ago.
10-21-2016, 08:58 PM
I cut my kick down rod and welded in a section of threaded rod to adjust the length.
10-21-2016, 10:27 PM
73FOMO
I need to get a welder and learn to weld properly. Last thing I welded was my wedding ring to a brake line when I was installing a battery cable
10-22-2016, 12:00 PM
10-22-2016, 12:47 PM
PapaBearYuma
73FOMO
lol...now that's funny
I bet it wasn't at the time!
10-22-2016, 09:56 PM
It's funny now, but it was rather shocking at the time...
PapaBearYuma
04-01-2012 12:25 AM
'83f3fiddy
18
06-25-2010 01:17 PM
ladelld33
08-08-2009 08:43 PM
ErrorS
09-10-2007 06:41 PM
400miller
06-06-2003 11:02 PM
