1988 F250 7.3 starting problem
Received 3,106 Likes
on
Update on my problem...was wire tracing the trigger wire back to the drivers side fender well where I found a large grouping of plugs. One plug had the trigger wire going into it and also had wires coming up from the transmission. About 6 out of 10 wires had their insulation gone and they were touching each other. I wiggled the wires and the plug and got a spiratic engine crank. I feel that this is where the problem lies. I need to find a twelve pin rectangular plug, so I can make the repair. Does anyone know where I can get this plug to replace the bad plug or should I just wire splice the ten wires and throw away the bad plug?
rblatch45
06-12-2015 04:52 PM
zach7.3
16
01-29-2012 01:06 PM
1985ColumbusF150
10-02-2004 03:43 PM
