Camming a 300-6
Camming a 300-6
I'm looking to cam my 300-6.
I was looking at a COMP Cams 268H (COMP Cams 66-248-4: High Energy 268H Hydraulic Flat Tappet Camshaft Lift: .456" /.456" Duration: 268°/268° RPM Range: 1200-5200 | JEGS), I've heard good things about this cam, but I don't know a whole lot about cams.
I want this truck to be a bit of a sleeper, I can't afford to swap out the motor right now unfortunately, so I'd like to give this motor a bit more pep till I can afford to swap in a 351C. I'm also going to re-gear it (thinking 3.55s or 3.73s) and swap over to a limited slip rather than open diff. I might lower the rear end a bit as well to level it out with the front, still unsure on that.
Anyway, what are y'alls thoughts on that cam? Seem like a good performance cam for the 300? What else would you recommend if not that one?
It wouldn't make it a sleeper, it would be the opposite. That cam will give the exhaust note a slight lope. You'll gain top end, and be completely bored with it in six months or the first day you realize that it's not much faster than it was stock.
I'd forget about it, and put all your money towards your goal of a 351C which is actually worth dumping money into, if you want real power.
James Clayton
04-17-2016 08:14 PM
maxoverdrive69
12-15-2012 11:13 AM
