1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Hub Bearing Assembly replacement
Old 10-15-2016, 01:49 PM
hewlettjohn's Avatar
hewlettjohn
hewlettjohn is offline
I am trying to remove the hub bearing assembly from the front end of my 2005 F-250. The job is really straightforward except for 1 part: the snap ring inside the center hub behind the 4wd locking hub around the shaft. This project has been ongoing for months and I have spent close to 200 on snap ring pliers and they either break, are too weak.. and the ones that are strong enough are too large to expand in the confined space.
I have tried drilling the clip dead center opposite the clip opening hoping I could weaken it enough to snap it in half. Bought a titanium metal bit for the job and it barely leaves a a mark on the clip.
Before I throw in the towel, does anyone have a trick to get this ^*&% thing off?
John
Old 10-15-2016, 09:53 PM
Magoo22's Avatar
Magoo22
Magoo22 is offline
The snap ring is a bitch to remove. I had to use a small screwdriver and a pick to get behind the ring and pull it out. It takes more then one set of hands but can be done. Finding the right angle on the snap ring pliers is tough. You can spread them but pulling them out is difficult. After spreading the ring get a small screw driver in there and then put the pick in and work it around the axle and it will come off. hold your tongue on the right side of your mouth and it will help as well. Good luck...
Old 10-17-2016, 07:36 PM
hewlettjohn
Thanks for the reply. I actually got it out about 15 minutes after I posted this question. I should have followed up.
What I ended up doing was used the latest pair of snap ring pliers I bought (they were long and thin, but stronger than the rest, but wouldn't open quite wide enough), I got the clip spread as far as possible. Then, with the fattest, largest flathead screwdriver I could find, I placed the head in between the plier ends (in the 'V' where it hinges) and twisted my wrist like I was rolling on the throttle of a motorcycle. The width of the flathead pressing against the inside of the pliers gave it that extra 3/16" of an inch spread and the clip popped right off.
Side one down, side 2 next weekend.
Again, thanks for the reply..
John
fourbyford
12-10-2011 11:31 AM
Richie.Rich
Offroad & 4x4
01-02-2011 09:49 PM
RIKIL
08-26-2009 07:42 PM
aRKToS
05-27-2009 08:44 AM
Mike12pt
09-26-2004 04:34 PM
Quick Reply: Hub Bearing Assembly replacement
