no power at radio
no power at radio
I have a 2013 F350 king ranch with the 6.7. Radio will not turn on, no power at the radio, however navigation system is working. I thought I would check with you all before spending God only know what with the stealer. Could
there be something miner causing this problem?
I have a 2013 F350 king ranch with the 6.7. Radio will not turn on, no power at the radio, however navigation system is working. I thought I would check with you all before spending God only know what with the stealer. Could there be something miner causing this problem?
Let us know after that!
If all the fuses check out, try disconnecting the batteries and leaving them disconnected for a half hour or so. When I changed my batteries, my radio would not come on. All fuses checked and nothing else was done. I did the disconnect above, and voila! Radio was back and back to normal. Well, I had to reset everything, but it all worked.
MudFlappin
1999 to 2016 Super Duty
06-10-2015 08:05 AM
Scarpa553
05-05-2014 03:35 PM
