How to Fix This Transmission Leak
I replaced the o ring. The old one did not look to bad, but seemed not to be seated. I pressed the new one back in there as good as I could. When reassembling I saw that there is nothing pressing tightly against this o-ring to keep it seated. I assume this is the way it is supposed to be, but was not sure. Assembly went o ring, bracket arm (which lays flat against the stud, but does not press against the o ring because it is deeper in there), NSS, lock washer, nut. The nut was stripped from over tightening (not from me) and would not tighten enough to flatten the lock washer so I have to go find another one at the hardware store.
I replaced 4 of the transmission pan bolts, two of which were missing and the other two were to short to tighten. Other bolts on the pan were also lose. I think that is where most of the leaking was coming from ( I guess I should have checked that first). It was definitely leaking from behind the o ring as well, but hopefully that has stopped. I will not know until I drive it which cannot be done until I replace the nut.
A thread pitch gauge would help here. AP stores as well as Harbor Freight have them cheap enough. I think you are going off of it being a 5/16's hex wrench size and maybe not the actual stud size. I could be wrong though.
Are the threads on the stud clean? Meaning, are they sharp and defined? A burr or burrs in the thread can stop a nut when trying to hand tighten it.
Will NF always be 5/16x24?
#28
#29
The threads on the stud are pretty clean. The problem is that the nut is almost smooth inside from the threads ripping out (I assume from somebody over tightening?). The reason I thing it is 5/16 is at the nut starts on a 5/16 screw better than any other size. It still screws onto the transmission stud, but it will not tighten enough to flatten the lock washer.
https://en.wikipedia.org/wiki/Unified_Thread_Standard
#30
