Mission for Today- Go Get Drive Shaft Built
Old 10-14-2016, 09:31 AM
Don Vito's Avatar
Don Vito
Don Vito is offline
Seems simple enough right? We'll see, nothing is ever simple! Once I get that done and bleed the brakes I shoud be able to fir it up and see whats what.
Don
Old 10-14-2016, 10:34 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Make certain you have the exact dimensions the builder wants and there should be no problems.
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Great! Hope you can put her on the road (under it's own power) soon!
Old 10-14-2016, 02:34 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Were all rooting for ya. It sounds as you have talked to Tad Drivelines in Phoenix, so as long as you measure the way they asked ,it will be a piece of cake. I would advise checking to see the correct torque spec when bolting it up to the rear end, I was surprised how little torque is recommended on those bolts/nuts. Rock on Don, your almost there.
Old 10-15-2016, 10:02 AM
Don Vito's Avatar
Don Vito
Don Vito is offline
Well, I measured, remeasured and measured again, went down, and I had to measure between the locking tabs on the rear end yoke, nd count the splines (31) on trans as some C^'s are 28 & some are 31.. so it should be done Tuesday..
Don
Old 10-15-2016, 11:30 AM
CBeav's Avatar
CBeav
CBeav is offline
I usually recommend to download and use a driveshaft measuring chart. It helps avoid confusion, brings up things that may not have been considered and could save additional trips to measure something forgotten. A good place to begin: Dennys Driveshaft How To Measure Correctly for driveshafts that fit right
Dude-Ford
13
11-27-2018 08:13 AM
CommanderCrzy
06-08-2015 01:48 PM
MauleOne
1983 - 2012 Ranger & B-Series
10-11-2014 08:38 AM
FreeDevin
02-17-2010 04:59 PM
badblueoval4life
03-04-2008 12:24 PM
Quick Reply: Mission for Today- Go Get Drive Shaft Built
