Notice: If you've had rusted bed rails....
Make sure you check the top of your rubber filler neck tube for a hole worn in it where the pinch weld on the bottom of the bed can come in contact if the bed rails have rotted out. I replaced my rails last year and today I found a leak, only when filled to full. After inspection, the rubber hose was cut right on top, where the pinch weld can touch it if the bed were to move down about 1/4".
