4speed to 5speed OD
Old 10-13-2016, 12:14 PM
mark460's Avatar
mark460
mark460 is online now
4speed to 5speed OD
I have a 1990 F350 7.3 IDI. Truck originally had an automatic transmission. Previous owner had converted over to a 4speed trans out of (85-88?? Ford truck), but it doesn’t have overdrive. RPMs are just too high to be driving on the highway. I think it has 3.55 ratio, but still to high for like 70mph.
What model truck would have a good trans to swap over with a 5-speed with an overdrive? Should I be looking for a ZF S5-42? Thanks.
Old 10-13-2016, 02:46 PM
madpogue's Avatar
madpogue
madpogue is offline
S5-42 or S5-47 will bolt up directly. The truck probably has a T-19b in it now. IIRC, the ZF5 is the same length as the T19 with bellhousing. You'll have to do your homework wrt. what clutch/flywheel to use. OBS hydraulics will work with some minor mods at the firewall, and the advantage is that you can get a complete pre-built pre-bled hydraulic set and not have to assemble and fill and bleed it (which is a PITA with our hydraulics). The other thing you gotta match up is the output(s) to driveshaft(s).
Old 10-13-2016, 09:07 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
I did this on mine, you can check my build thread for some info and there's a ton of data on this in the FAQ thread.
Old 10-13-2016, 09:22 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
The frame for m current build was an 85 with a 6.9 and T19, I dropped my 7.3 and ZF in place, and the driveshaft bolted right up. The cross member does need to be moved back a couple inches, though, but that's just drilling a couple holes. So, at least for a 2WD the five speed is a bolt in swap.
Old 10-14-2016, 02:02 PM
mark460's Avatar
mark460
thanks for the info. I'll check out the FAQ. Now the hard part is going to be trying to find a good deal on one.
Old 10-14-2016, 09:05 PM
wtroger's Avatar
wtroger
wtroger is offline
I have one in good shape. $400 local pickup on southeast Ks, Ok border
RenoHuskerDu
83
01-23-2019 12:32 PM
97squarebody
06-09-2016 10:02 AM
Capitlj
17
12-12-2011 06:27 PM
custom1106
04-25-2011 03:15 PM
gearhead351
09-01-2007 08:36 PM
Quick Reply: 4speed to 5speed OD
