I'm having trouble disconnecting the transmission lines to replace them. I can't get them off. I have the tool. Can I replace the fittings in the radatior?.
Well i ended up buying a new radatior for that truck. But I found these https://www.amazon.com/DORMAN-800-617-Transmission-Cooler-Connector/dp/B00HEBT388
For the future. Hopefully it helps someone with the same problem.
I've been told if you replace the fittings, do them one at a time - the fittings are all that hold the internal part of the cooler in place. Not from personal experience, luckily for me someone told me before I might have found out first hand, lol.
