1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Automatic shifting problems
Old 10-11-2016, 08:31 PM
kimara3002's Avatar
kimara3002
kimara3002 is offline
OK. Trying to see if anyone has had this problem before I order parts I don't need.. my column shifter is loose or seems that way. The peg never likes to end up in the position the vehicle is in even in park. some times the shifter doesn't click in all the way into the gear or clicks out to easy etc. When I'm in standard drive I can move the shifter back and forth probably close to a full 1/2 inch or more overall. From what I gather and I haven't looked to far into it yet it's either going to be my column shifter itself or the shifter cable needs adjustment or replaced. So has anyone had this problem yet and what fixed it for you?? Thanks
Old 10-11-2016, 08:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
A few details about your truck might make this a lot easier to diagnose. Start with what model year.
Old 10-11-2016, 08:42 PM
kimara3002's Avatar
kimara3002
99 250 super duty, ext. Cab 6.8 v10, auto transmission, 4x4 manual shifter on the floor
Old 10-11-2016, 10:50 PM
BAJACRAZY32's Avatar
BAJACRAZY32
BAJACRAZY32 is offline
I'm not a master mechanic, no where close to mark but I did have the same problem. I adjusted the shifter cable and it seemed to work fine. Tightened it up very well. Try that first and if it doesn't work try other option
Old 10-12-2016, 08:46 AM
Mark Kovalsky
The first thing to check is the two #30 Torx screws that hold the shift cable bracket to the shift tube on the bottom of the steering column. Crawl under the dash and look back up the column. These two screws tend to loosen and cause these problems.
Old 10-12-2016, 06:38 PM
kimara3002's Avatar
kimara3002
Was able to get up under the dash after work and they looked tight amd couldn't move them with my fingers but when I put the wrachet to them they were indeed not right at all. The one closest to the column was 1/4 or more loose. Needless to say got them tightened down and now the shift seem to work well and distinguish between gears. So that advice worked perfectly and I thank you for it. Found another problem while I was down there though. My gear selector peg needed adjusted so I went to do that and go figure the white plastic housing for the black adjustment gear is broken.. so got some wire and looped it through an empty hole on the dash frame and I've the cable housing and pulled the housing with wire down to the point of where I would have to adjust it to make the peg to its proper point.. so now the peg lines up with the gear.. so all n all I guess I had two problems which you helped me with my main one so thanks again!
barrett74
07-06-2012 10:41 AM
breno1987
08-10-2011 05:08 AM
uofmgriz
1983 - 2012 Ranger & B-Series
04-10-2009 08:09 AM
KJKozak2
Offroad & 4x4
16
01-13-2005 03:46 PM
Quick Reply: Automatic shifting problems
