390 Exhaust Manifolds - Ford Truck Enthusiasts Forums
Old 08-22-2003, 07:10 PM
HardFordCore HardFordCore is offline
HardFordCore is starting off with a positive reputation.
I am a new user here and found the FE Forum thankfully. I have 66 F100 Short Bed Custom Cab non-step side. It has a 390 and cruiso in it now. I am tossing out the headers so I can have reasonable access to the starter and it doesn't get barbequed by the header pipes. I came across some exhaust manifolds and had them surfaced. The passenger side has a small crack though the port on #2 cylinder. I can't see where it was leaking exhaust but it will in time I am sure. I am going to use it now as I need to have the exhaust system done in order to drive it. Later, down the road, a good one will come along. But for now this truck needs to hit the pavement. Does anyone have a recommendation for exhaust gaskets and what is the torque spec for the bolts? I used some copper gaskets for the headers but don't know it this best for cast iron manifolds. What grade of bolts and washers are best for the manifolds? Thanks for any advice.
Mark
Aptos, Ca
Anybody going to West Coast Nationals in Pleasanton this weekend?
Old 08-22-2003, 07:40 PM
FEmtnmax FEmtnmax is offline
FEmtnmax is starting off with a positive reputation.
My engine gasket kit came with stamped steel gaskets, not a thick sandwich gasket. I don't have torque specs, but try a X tightening pattern starting with cylinders 2&3 or 6&7. Snug them down. Run the engine, When its cold the next day snug them up a little if they need it. With that thin steel gasket the bolt will be either tight or snug or loose. Just telling what I've done in the past. I guess I'm not the total purist. Gaskest set was Felpro.
Old 08-23-2003, 02:48 AM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
Grade 5 bolts should be fine, use lockwashers and torque them to 12 - 18 ft. lbs. Try the Fel-Pro comp/steel gaskets like mentioned above, put the steel side facing the manifold.
Barry
Old 08-23-2003, 08:07 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
If you want to add to your exhaust anchor (oops! ) I mean't manifold collection, I've got some due to go to the next world war scrap drive. If you'll pay the shipping, I'll send them. Give me headers anyday on an FE, unless it's in a Stang.
Exhaust Manifold Leak/Headers + Full Exhaust JLuskin 1987 - 1996 F150 & Larger F-Series Trucks 10 08-26-2015 01:18 PM
Headers for 390 FE & Volare front clip Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-06-2015 12:20 PM
Exhaust manifold leak Fish_Scientist 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-01-2010 11:31 PM
exhaust manifold gasket Old Brown Truck 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 05-08-2010 12:05 AM
FE exhaust manifolds HardFordCore 1961 - 1966 F-100 & Larger F-Series Trucks 22 08-30-2003 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
