Rutcutter took a photo of the 35 inch Toyo RT between the tread and the control arm and there was about half an inch clearance. He said the 37 inch tires rub "a little."
But that was after the leveling kit was installed I think.....
Bat, please post pictures. I think it will work, but sure would love for you to confirm!
295 Michelin LTX fit perfect. Fill up wheel well nicely.
Nice looking ride Bosox. Did you do a tire swap at the dealer? I ordered mine with the AS tires and did not figure out until later the AT's have a higher weight rating in the 70 aspect ratio. I was thinking of going to the 285 to add a little more rating without too much more tire face on the highway. Your thoughts on the 295's? Thanks
I had the dealer change out the Michelin AT's that came from the factory before I took delivery. I have had most major brands of tires on my 350's over the years. Toyo, Nitto, Bridge, Goodyear. I have found the LTX to be an excellent tire on the highway and in snow/rain/ light offroad. I spend most time on highway and it is a quiet tire.
