12 6.7 Snow Birding Storage
I'm toying with the use of a Battery Tender Jr. on my 2016 6.7 to be stored through the winter in unheated garage. Vehicle will be started about once every month or two. Does anyone know the actual parasitic load the trucks electrical system places on the battery? In theory, assuming both batteries are fully charged to begin with, and a well ventilated cool wintertime indoor location for the wall wart, I would think the Jr version should do the job at .75 amps output. The next larger version produces 1.25 amps, and I'm doubting that is necessary for long term storage. I am told the 1. 25 amp version has temperature compensation, and the Jr. 0.75 amp version does not. But I'm not sure what the temp compensation actually gives you. Thoughts on this?
I handle medical imaging equipment and whenever I crate up a CT. System or an MRI or other x Ray system I just clean it up, wrap it with shrink wrap with a bunch of silica packs thrown into the insides.
I know it's easy since I have materials and do it regularly, but I'd be tempted to wrap the whole thing in heat shrink plastic with a dozen or so silica bags all over.
Just a thought.
Just a thought.
Seals drying out?
Just reading "fitrv.com" discussion about diesel vs. gas. One post on RV use of diesels. Post states that seals can dry out on a diesel that sits a lot when only used as RV.
Can anyone elaborate on that? Have never seen this mentioned in this blog, and I've been reading it for years prior to signing up in August after I bought my truck.
ad16
Aerostar
16
01-20-2017 01:46 AM
pineconeford
21
02-26-2015 04:13 AM
