V10 Engine Squeal
Old 10-09-2016, 08:16 PM
ljs05's Avatar
ljs05
ljs05 is offline
V10 Engine Squeal
My Excursion has started with a weird engine squeal. The truck sat for a few weeks and now it has a squeal when driving, starts at about 2500 RPM and stops each time it shifts. Will not do it in neutral. Kind of sounds like when an alternator bearing goes. But I removed the serpentine belt and drove the truck quickly. The noise was still there, so that eliminates all the front belt components. Anybody have anything similar ever?
Old 10-09-2016, 08:48 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,180 Likes on 811 Posts
Is it a top end or bottom end squeal?
Old 10-09-2016, 08:56 PM
ljs05's Avatar
ljs05
ljs05 is offline
V10 Engine Squeal
Cant tell. Echos all over the place when driving and will not do it when parked. Only way I can do it with out driving is with about a 2000 RPM reverse power stand. and then there is so much other noise you cant tell where.
Old 10-10-2016, 05:27 PM
Lexx's Avatar
Lexx
Lexx is offline
Drive [POSSIBLE] train noise since its moving and squealing. Cancel that since you went 2000 rpm reverse standing on the brake
2 wheel, 4 wheel drive
Wheel Bearing(s)
Brake pads, disc, caliper
Drive shaft yoke
Transmission
2500 rpm in OD or out
Maby torque converter or vacuum leak
ripstar1
1997 - 2003 F150
09-24-2013 08:10 PM
LittleRadio
04-10-2011 01:12 PM
Ralphspal
1983 - 2012 Ranger & B-Series
21
05-24-2009 02:59 PM
BLACK95GT
1999 to 2016 Super Duty
11-06-2006 11:53 AM
6.0 Rules
06-14-2005 05:29 PM
Quick Reply: V10 Engine Squeal
