V10 (Excursion) making weird noise and acting strange
This has been going on for about a year or two and I had a thread here on it but I had no money to get it checked out. I got used to it doing this so when I got money last year, I simply forgot to have it checked out and of course, now I'm broken again.
Anyway, it only did this when I was driving and hit the gas. It would drop a gear or two, pick up speed and at the end, when it was through accelerating, it would make this sucking noise. The longer I would hold the pedal down and then let go, the longer it made that sound. Only a second or so mind you.
Check out the first sound file (# ending with 114). At 0:13, you can hear me kicking the gas down and at 0:21, you can hear the sucking sound.
TODAY, it start doing it differently, it started doing it when I took off and not only was it louder, much louder, when it changed gears, it did not change gears as smooth as it used to and and it kind of moved the truck/shook it or whatever the way it does when you change the gear manually and let out the clutch too fast.
Check out the two other files for the way it sounds now. ALL are taken today but the first one was when I was already driving at a certain speed, kicked down the gas and it did it. The other two was when I took off from stand still.
Especially the rough gear change is freaking me out as I have no money and I can't fix a damn thing and I'm worried it might be something expensive.
Volume up as it may be hard to hear. You'll hear a swooshing/sucking sound.
This is a 2005, Excursion with a V10 and around 80k miles. I don't drive hard and I don't tow and since I got it, oil has been changed regularly at a ford dealership every 3k miles.
File # ending with 115
sucking sound at 0:11
File 116
sucking sound at 0:10
I forgot to mention. Twice today (first time right before I wrote this and the second time a couple of hours later when I left the house) the overdrive light (on the arm on the right side) was blinking OFF and I've never seen it do that.
Anything to do with my sound problem? Also, is the overdrive light supposed to be off or on? I NEVER tow anything.
Thanks
File 116
Thanks
Ok, I'm totally stupid so I'm going to the shop. Was going to a local shop first since he also drives an Excursion AND I think his is a v10 too but not sure.
So, tell him to check the vacuum lines? Is he looking for leaks or something?
Should I go to the Ford place instead and have it checked?
Hey, the mainfold vacuum and all that, is it supposed to make the sound? It didn't the first years I had the truck. I assume it's not and if it's making noise it's 'cause something is going on?
Thanks
Thanks
OD blinking means the PCM sees something wrong with the transmission - BUT it could be a few different things, including the ABS sensor on the rear end.
Bring it to the local shop first, have them check for codes and see what's going on.
It sounds like you have a big vacuum leak somewhere. Should be easy to find.
Well, I replied but something happened to my reply so I'll post this again.
They tell me I need a new transmission. Rebuilt one around $3k and 2 year warranty. New one (not sure if it's a used or completely new one) for $4.5 and 3 year warranty.
A buddy of mine who used to have a pretty big shop suggest I try putting some transX in it. He said he had a vehicle that couldn't change into the last two gears but put some transx in it and it's still running fine. What do I have to lose?
Gonna take it to a local guy that does transmissions and has a great reputation to see what he says.
The light should be off.
If that dealer is trustworthy, then yes, you can trust them. If they are not trustworthy, then no, you can't trust anything they tell you.
Good idea.
It doesn't sound like your very mechanically inclined.... Please don't take that as an offense. If you feel you are, you might want to see if your transmission has some loose feed bolts.
It really only costs you 2 hours of time, possibly $100 in trans fluid if you don't save your existing fluid.
https://www.ford-trucks.com/forums/1...wont-work.html
I kept getting mixed opinions and people said the feed bolts were not my problem, but I decided to take a shot and it paid off big.
Absolutely NO offense taken. I couldn't turn two bolts if I had to.
I DID go to a local guy that specializes in transmissions with a very good reputation. I talked to him today. He advised against the TransX. He thought that the dealership comment that it wasn't a solenoid was prolly bull as they were trying to sell me a transmission and he said that IF he had to rebuild it, it would be 1500 bucks. He also said that he would drop the oil pan (I assume) and look and then if he thought it was needed, he would change the solenoid. If that fixes it it's around 100 in labor and around 150 for the part. IF NOT, he said, he'd take the part back and I just pay him labor. Can't get better than that I think. I have an appointment with him on monday so let's see what he says.
I would HIGHLY recommend him checking the feed bolts, if he is pulling the transmission pan anyhow to check the solenoid. It should only take him a half hour longer and they are a common thing to back out on these trucks. Possibly send him the picture of the feed bolts or show him on a phone so he knows exactly what you mean.
Alright, I'm back after having the local transmission guy check it out.
First, he did not know what feed bolts are. Maybe he did but not by that name.
Anyway, he said he was gonna drop the pan and check the oil and take it from there. I guess when doing that, the oil didn't look too bad so he changed the solenoid (replaced with a used one) and the accumulation pack and drove it a bit and said it seemed to run better.
He came to my house to pick me up and as soon as I took it out to drive it, it started doing the same things again, at which point he refunded all my money. Kudos to him for that. While we were out, the overdrive started blinking again but his code reader couldn't read it so he sent me to another guy with a more advanced reader. He got some kind of error so we have no idea why the lights blinking or rather, what the computer says.
So, here's what it does. When it changes gears, the belt (whatever belt that is) slips. The shift point is too high...when it goes from 1st to 2nd it shifts at around 2500 to 3000 rpm instead of 1500 to 2000. It's falling out of gear and at some points, it won't shift.
Don't suppose there is someone in the Charlotte, NC area that is really knowledgeable that could take it for a ride?
The previous owner rides like I do, not aggressive or fast at all and no towing.
Most of his and my driving is start and stop, very short distances.
Thanks
Thanks
