I can't seem to get the air bled from my brakes! 04 Scape
I caused it to skid, which I can't do in the dry because the brakes are still too squashy and weak, but I thought I felt a little skid, plus got the ABS light to come on, so I'm hoping to have gotten the ABS pump to work, expelling air. I guess I need to do a four-corner brake bleed again after that.The pedal feels the same, but I figure that I only got the air out of the pump, now I need to get it the rest of the way out of the braking system. Am I right about this?
I'll tell you how it finally worked out
I found a gravel path where there is road construction and got up a little speed and slammed on the brakes to get it to skid. I did this a few times. The ABS light came on, like it's supposed to. Then, I went back and bled the brakes again. The pedal was solid after a pump. Something I noticed was that the fron t brake rotors had spots of rust build-up and a dark, blackish glaze, which was contributing to a slow to stop problem. I drove it around a bunch in areas where I would be unlikely to have to panic brake, though I did stop very hard when nobody else was present to clean off the front rotors. Now it stops pretty well. I guess I had air in the ABS unit. Forcing it to function cleared the air out. Thanks for all the time and input on my problem!
I think you may still have some air in the ABS, but don't bet the paycheck. My understanding is that there are lots of passages and multiple little pumps that diddle the pressure to each wheel individually(or not...), and getting them to be airless would require more cycles than would be normal. Again, don't bet the check. Some scan tools may be able to engage the ABS, forcing it to cycle the individual solenoids and ??? inside. Other than that, it would be brand specific, Bendix, Bosch, etc.
If you have a good pedal, you should be ok. The brakes should start to work with minimal motion of the pedal, such as 1/2" or so, and should be 'modulateable', gentle touch to full slam.
tom
tom
quakerj
08-25-2013 11:51 PM
