Wheel Well Liners
#46
I picked up the Husky liners for $92 delivered on Amazon. Hard to tell from the pictures, but are the Rough Country a little shorter?
I tried to install mine last weekend, but it was below freezing and I couldn't get the liner to fold into place it was so cold. I might also have to remove my WeatherTech mud flaps and reinstall after the liners. I'll know in the Spring when things warm up and I can set the liners in the sun to make them more pliable.
#47
I had to remove my factory mud flaps to install the rough country ones. I also had to trim the liner by 3/8 in on the bottom towards the mud flap because they were to long and were pushing the flap down so they couldn't be reinstalled properly. I used a dremel with a plastic cutting disc that I used to cut vinyl siding this summer. Made a nice cut wouldn't even be able to tell I cut them. That sounds like a good deal for the huskys. What do you mean by short? Also it would be hard to install them if it was below freezing I got lucky and had a day close to 50 wasn't hard to install them in those temps.
#48
#49
Mine do expose most of the shock and frame. I think the design is different because most of the others posted seem to have a smooth flat back panel and mine has 2 raised spots on the back panel as you can see in the photos so I'm sure the designs differ slightly between manufacturers. Honestly I like all of them equally to I think they all look great ford, husky, rugged liner, rough country. I feel that they give the truck a nice finished look and it helps that it keeps alot of the nastiness that can acumulate out then you just spray them out clean.
Race Red F-250
2017+ Super Duty
09-02-2018 10:03 AM
