P0304, 4.2 engine, need help diagnosing
My E-250 4.2 has continuous miss on cylinder #4, p0304 changed coil pack, wires and plugs, No change. Cats were replaced a year ago fuel trim readings as low as -96.7%' as high as 53.3%. Would a cracked exhaust manifold cause this problem, after replacing coil pack, plugs and wires I noticed the crack between cylinders 5 and 6 on the engine side of the manifold about 1.5" long thickness of about sheet of paper. Here Is a picture of the fuel trim codes.
