1992 - 1996 parastic draw test
Anyone familiar with doing a parasitic draw test on our trucks? Battery was dead flat a week ago. I know the battery us fine since i load tester the battery and it was still putting out 900 cca for 45 secs after a full recharge and didnt even drop in voltage. after the test was complete. I have since done a google of how to do a parasitic draw test but i may have blown the fuse in my meter since im not getting any amp draw not even the 50 mma. I conducted the test with the negative lead off , i also tried with the positive lead off and still nothing ? Am i conducting this tests wrong since i know there should be some amp draw but my meter says 0.00 across the board
I use a low voltage test light between the positive cable and the battery everything else hooked up. Save the under hood light. If light comes on there is a draw if not then there isn't enought to worry about. Most Fords only draw about 5-10 milli amps with 20 milliamperes being tops. The draw is for keep alive memory circuits in the PCM and radio.
So threw in a new fuse this morning and im starting to get some readings now first reading was at 80 - 90 Milli-amps but once the surface charge dissipated i was starting to get a reading of 35-40 Milli-amps draw is this a normal reading from what i understand if its under 50 milliamps i should be good but if what wtroger is saying is tru about the 5 - 10 mill-amp it may be excessive. Like i said i know there should be some draw , i just want to knoe if what i have is excessive for a 5.0L e40d sd setup
Well, if 20 mA is the top side of the scale and you are getting twice that then there is something amiss.
I'm guessing the reason you ask is it killed the battery in a week of sitting?
As for meter vs. light. The meter will give you the exact amount. The bulb will just let you know visually.
I have bought new batterys that actually were bad off the shelf.
Easy test: disconnect the battery, let sit for a day, check its voltage and current.
Or use a known good battery in the truck, let sit for 24 hrs.
"Known good" doesn't mean new-off-the-shelf, it means "works OK in another truck".
Listen Im not going to turn this into a bad battery thread , its the same battery i ve had for years. Like i said i work at total battery , i checked all the cells and the hydrometer says there healthy , i out it on a 3000$ load testing machine not the ****ty ones u buy off the shelves at local auto parts stores and it put out 800 cca for 45 secs with is over kill considering that would be a load test for a deep cycle. All I want to know is if 30 mill amps is excessive draw as i know for most new vehicles its 50 millamps
