Ford 302
Ford 302
I have a 302 ford I got told its early 70s 74 I believe the code is d4de-aa, it came out of a 76 mustang. Did ford keep this casting up to late 70s and what the difference between this number then a truck engine? Any difference between car and truck 302 in 73-79 thanks in advance
on
This was still a high compression motor up until 1975 and if it's an original Mustang engine or been rebuilt to that spec it would also have a decent cam. Only other thing of note would be the lack of hardened valve guides in the heads unless they have been previously upgraded or replaced, did you find casting numbers on the heads?
chevystepside
17
03-15-2010 12:12 AM
fordguy49
10-09-2003 01:45 PM
