T98 Input Shaft oil seal
Old 10-03-2016, 11:54 PM
kj6opf's Avatar
kj6opf
kj6opf is offline
I am currently having my 223 rebuilt for my 60 F350. When pulling the motor, noticed that it looked like some oil had leaked from the transmission. Figured that the oil seal on the input shaft should be replaced so went through removing the bearing retainer, etc but cannot remove the input shaft bearing to get to the oil seal.
Am I going about this the right way?
Old 10-04-2016, 03:33 AM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
[QUOTE=kj6opf;16620199]I am currently having my 223 rebuilt for my 60 F350. When pulling the motor, noticed that it looked like some oil had leaked from the transmission. Figured that the oil seal on the input shaft should be replaced so went through removing the bearing retainer, etc but cannot remove the input shaft bearing to get to the oil seal.
There is no oil seal on the input shaft just an Oil Slinger on the back side of the bearing. Oil should never come out the front of the input shaft unless the trans is over filled or it is tipped forward.
Old 10-08-2016, 11:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Parts catalog picture in order of appearance:
7050 = front bearing retainer / 7051 = front bearing retainer gasket / 7064 = snap ring-input shaft bearing to shaft / 7070 = snap ring-input shaft bearing / 7025 = input shaft bearing / 7040 = oil baffle-input shaft bearing / 7017 = input shaft.
df85732
04-10-2017 09:18 AM
tommyl
07-18-2010 08:44 AM
Black89F150
03-13-2005 08:03 PM
Quick Reply: T98 Input Shaft oil seal
