Steering wheel removal. How to?
1997 f350 xlt auto. Picked up a used nicer steering wheel for my truck since there is absolutely no leather left on my stock one. Did some reading and couldn't find a good write up on how to remove the wheel? I'm assuming disconnect both battery's, then lossen the inner nut and wiggle till its pops off? Should I worry about the clock spring or ujoints? Thanks Kyle
Pm me your email address and I can send you a PDF instruction sheet.
Received 3,090 Likes
on
you do not HAVE TO disconnect the batteries, but it is not a bad idea.
unscrew the two screws on the back of the wheel holding the pad on.
remove the nut. then using a 2 jaw puller, put the jaws in the indents on the back of the wheel at 12 and 6 oclock positions, and remove the wheel.
some people have luck loosening the nut until it is flush with the end of the threads, and pressing their knees to the wheel and then whacking the nut with a hammer, but i do not believe in that method.
on
No air bags on the 97 f350/f250 HD. No screws that hold the center pad on, just 2 clips. To remove center pad, carefully pull the center pad out towards you while sitting in drivers seat. You can get your finger in between the pad and the column cover, just in front of the hazard switch. It will pop out of the clips, then there are 2 wires for the horn that need to be unclipped, and the pad will be free.
