Been up in Weiser, ID visiting an elderly aunt and uncle. Long drives each way, though Marge's Pilot performed flawlessly.
Lots of nothing out on some stretches of US-95, and when I re-set the "max speed" on the Garmin it read 92.3. I'm sure that happened while passing a truck (or something), but still faster than I (or the legislature of the State of Nevada) want us to be traveling.
My superduty is 93mph in stock programing.... and runs outta power after 115mph in modified programming. Havent found the speed limiter in the van yet, but i also havent had it out in no mans land yet to test it alone.
I once had the Scurge up to 93-94mph (back when I had stock sized tires) when there was a noticeable drop in power. I assume that was a limiter at work.
Good morning SoCal. Had Black up to 96 passing someone. But, I think the tune takes out the limiter, not sure what her top speed is now....and not sure I want to find out!
Couldn't pass on adding another pic, not in the Sierra's as so many have been recently posted, however, a facility that probably only one So Cal member would recognize.
Wonder if any others would seed the light?
