Adjusting Doors
I found a really bad way to do it. If you unbolt the door from the hinge you can get at the bolts holding the hinge to the cab. So you move the hinge on the cab, put the door back on and see if you guessed right. Then you take the door back off and try again. It's almost impossible to get it right that way, but you might be able to get it good enough.
When I swapped the '95 front clip onto my '88, the only way to adjust the doors from what I could see would be to have the fenders off. Fenders aren't that hard to take off if you're mechanically inclined. Just make sure everything is unbolted from it in the engine bay, undo the fender liners, unbolt from the rad support and the cab, support the hood with a prybar or chunk of wood, and you're good to go. If you're doing both, take off the hood and you should be able to do it within a day
jimpennycuff
12-01-2006 12:43 AM
F 2fifter with a 4 sixter
02-02-2005 09:03 PM
