engine swap
engine swap
Hi, I am new here,hope i am posting this in right place. I have a1992 f150 with a 5.0 and 5 speed. My ? is the motor is toast and i found a very low milage 1994 f150 with a 5.0, From what i am reading is is not a direct swap. Please tell me what i need to swap on it from my old motor to make this work,Thank you
the 94 is likely to be a HO
I did this swap in my '93 Bronco. for the "new" motor, strip the intake and sensors off. swap onto it all of the stuff from your 92
keep in mind, that if the '94 motor is a HO motor the firing order will be different. if the HO, it will have the 351 firing order.
on
The '94 is not a HO motor but it does use the HO firing order. It is a direct bolt-in but do not attempt to use any wiring that comes with the donor, remove the upper intake and disconnect everything right at the motor and then just reattach your trucks original wiring once the motor is in place.
