Seam in back of cab To fill or not fill?
I have done a few...some were reworks of failed jobs that owners had done DIY. It has been my experience that if a non-welded seam is going to fail that it will do so at the corners. A seam doesn't have to be in a seamless (no pun intended) bead but it does need enough weld to keep the seam stable. Clean the seam well and wire brush it to remove any embedded paint and/or seam sealer. Tack weld across the seam at about 1/2 inch intervals. Grind the welds flush and fill the remaining seam with structural adhesive (3M 08115 works great). Sand and finish with body filler and then primer/paint.
on
Received 4,116 Likes
on
On both my builds I filled all the seams by welding them up and body fill, I like the smooth flow but there is another thing to consider and that is if there is ever any damage to repair down the road those seams give you a body break you can mask a section off and not have to try and blend in the repair..
Marty Smilt
10-02-2010 01:41 PM
MMToy12
05-01-2004 07:21 PM
