Preparing to Replace Front Springs - Any other parts I need before I start?
Getting ready to replace my front shocks and springs on my 78 F100. This is the first time I have ever replaced springs before, but I have searched here and found a few threads which have provided me some guidance, so I think its not going to be very difficult.
I have the springs already. Got the best ones that NAPA had. I can already tell that they look a lot thicker than the originals. Hoping that's not a bad sign.
Anyway, Do I need to pick up any additional parts? Does the spring sit in any sort of cradle or on a vibration dampener that I probably should replace?
Also, while I am down there, should I knock anything else out? I am not familar with exactly what the names of each and every part, but I found this diagram, which looks pretty similar to my truck, minus the steering bits. I do have a picklefork that I used once on a toyota, and I am not afraid to use it again.
http://repairguide.autozone.com/znet...3f802123b5.gif
Here are a couple pics of what I saw when I jacked up the truck and stuck a camera down on the driver's side. I plan to get some pics of the passenger side tomorrow.
https://goo.gl/photos/T9ptchjwyu9DADD67
https://goo.gl/photos/exhQuDQKBHdUD6uQ9
Soaking began last night. Next I need to dig up the threads I've seen before in this topic and head over to tractor supply and pick up the proper size
Well, you'll definitely need a jack, a couple of jackstands, and a torque wrench. You may want to borrow an external-type spring compessor or at least put a safety chain through the spring to keep it from exiting it's home in a most violent manner when you let the LCA droop...those things pack a LOT of energy and can seriously hurt you when they unass themselves.
Seems like a good time for ball-joints and radius arm bushings, but those can always be done later and are projects unto themselves unless you don't mind having the front end blown-apart til you can get it all done. If it's a daily driver I'd tackle one project at a time....you can always come back to it once your knuckles have scabbed-over (less risk of infection that way. SAFETY FIRST!).
The spring can be removed without a compressor. It is retained to the spring bucket by a retainer clip. At full droop, the nut can be removed and it will slowly release compression as the nut is loosened. Then the spring will hang there until the retainer clip is unbolted... not a whole lotta drama involved.
Thanks for the reply.
I also plan to pickup a 1 1/8th socket and wrench.
Was definitely thinking that I would tackle the radius arm bushing at the same time. After watching this video it does not seem to bad
A 2WD Dent doesn't have ball joints.
What else should I replace while I am down there? The steering bits (not sure what they are called) look a bit nasty. See below.
https://goo.gl/photos/tnzzeefVJ49Pcpbs9
Good Lord willing and the Creek don't rise I'll have El Toro Marrón on the road in a couple more weekends with fresh tags and a stamp of approval from the smog *****.
All apologies to the OP for the momentary derail.
I'm learnin' new stuff every time I come here...thank you. Are the 4wds much different? I haven't dug into the front suspension on mine yet...still vanquishishing vacuum leaks and unF-ing PO hackery. I may be a hack, but not this brand of hack...Holy catz.
2x... hackery sucks. I'm still undoing residential hacks.. one time I got lazy and didn't turn off the breaker to replace a light fixture. I was up on a ladder and got zapped because the idiot who installed the circuit switched the neutral. Meaning, the black wire at the fixture was hot all the time!!!!
Back to the thread.
If some suspension and steering parts are currently worn, good chance all the stuff has wear on it. New steering linkage, inner/outer tie rods, kingpins/kingpin bushings, I-beam bushings, radius arm bushings and new shocks will go a long way towards restoring the front end to handle and steer like the struck was when new.
Most of that stuff; springs ,radius arm bushings, shocks, is fairly easy to change. If you replace tie rod ends, make sure you have a front end alignment done. If the kingpins are tight, just grease them. If the bushings are worn and need replacing, save yourself a lot of headaches. Take the I-beam/knuckle assy. out and take it to your local machine shop and have them do it.
My thinking is this, If I can knock it all out I will never have to do it again. I barely drive the truck, and it's parked in a garage. It was my father-in-law's truck, had it for 10 years, and will never sell it.
Here is a good video that I found that seems like it is pretty much a good guide on how to get everything apart. Seems like a bit later of a model with front sway bar, which I do not have, but I figure it's close enough.
So I had about 2 hours and went to town on the passenger side.
I need to pick up a deep well socket and wrench to loosen the i-beam axels. I believe that they are 15/16.
Regarding the ball joints and steering linkage. Does anyone know what each piece is called? Do I just remove the entire assembly and replace all the joints?
