2011 Flex Entertainment system issues
Old 09-29-2016, 05:33 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
I have a 2011 Flex Limited with the integrated entertainment/navigation system. I have a couple of problems with it. First is the left rear DVD player, DVD A on the touchscreen. It will not turn completely off either from the rear seat or dash touch screen.
The second, and bigger problem is the CD player in the dash, inserting a CD results in a spinning disc icon and "analyzing disc" followed by on the bottom right side "bad disc or unrecognised format". using a CD player cleaning disc did not help. As a result I am unable to update my navigation system software.
Short of pulling the whole system out (and rendering the vehicle unusable) is there any way to find where the problem is and fix it?
Thanks.
Old 09-29-2016, 06:28 PM
madsonp's Avatar
madsonp
madsonp is offline
Thanks.
I think the first thing I myself would try to do is to pull the fuse then reinstall it to see if it'll re-set the system.
Old 09-30-2016, 04:49 PM
85lebaront2
Well, I tried pulling all three of the fuses, no luck. Found a used radio/CD player on eBay for $203.02 with the correct engineering number BA8T-19C156-BB and it will be here Thursday.
Old 10-13-2016, 06:09 PM
85lebaront2
Replacement didn't fix it, but UPS had beat it up a bit, so that was a ??? issue. Got another one, but before I tore the interior apart again, I decided to try something. My driver's side rear DVD player, DVD A, was staying on no matter what. There is a TSB from Ford, 11-3-30 describing the problem. Apparently, with DVD A on, the dash unit is either locked out or unable to properly read either a CD or DVD. I removed DVD A from the driver's headrest and unplugged it. Went and got my update discs and everything installed like it was supposed to.
Metalhead47
09-14-2013 12:16 PM
2manykids
11-13-2007 01:58 PM
photomac
08-18-2006 10:23 PM
CampingFamily
1997-2006 Expedition & Navigator
04-26-2004 10:39 PM
Templer
2004 - 2008 F150
11-30-2003 07:29 PM
Quick Reply: 2011 Flex Entertainment system issues
