1984 F150 - Heater Cable w/AC - replacement needed
I'm in the Savannah, GA area and I'm trying to find a part. My heater/temperature control cable (that runs to the heat/ac mix door behind the dash) got a sharp kink in it and I can't repair it.
None of the salvage yards that I've called have it, and LMC truck no longer sells it either. I've searched the forums on this site for clues on where to find one and I called a handful of the suggested places a couple years ago, but then gave up.
I've tried reverse engineering a choke cable, but that didn't work for me. Just want to know if any of y'all have tips or tricks to get a replacement (even if it's another DIY suggestion).
Thanks in advance. Everyone on this board seems pretty helpful so far.
There is a yard in Griffin may have it. I got to work on mine once I get paint . If I was headed to Johnson's I would check for you. Finding that part in a yard is going to be a physical go and look they do not put small stuff like that in the database.
Go to our monthly chat and ask if anybody is headed to a yard for anything and see if they will try to find one for you. I am sure most would grab one for you and ship to you with reemburstment of course.
Thanks, hturner12. I'll have to see if I can head up there or give a call to see if anyone there is motivated enough to take a peek for me.
I may have to try my choke cable idea again. I really just need the plastic pieces that guide the cable. If I had those pieces, then i could use just about any push/pull cable cut to size. Two of mine broke because they were so brittle.
I'm a tech guy, so I'm wondering now if I can find someone with a 3D printer who can churn those out for me... hmmm....
on
PM either numberdummy: Ford Truck Enthusiasts Forums - View Profile: NumberDummy or Mike : Ford Truck Enthusiasts Forums - View Profile: mikeo0o0o0. Tell them what you are looking for and they can help you out, it would be a new one.
https://www.ford-trucks.com/forums/1...-operated.html
This may help
I may get a chance to run up to Johnsons in about a week. If I do I will check and see if I can find the cable. Got to get at leat the black color on so I can get back in the cab.
This may help
I FINALLY found one at a junkyard today, but guess what? The owner won't sell it to me because he "wants to sell the whole truck". The body is in decent shape overall, so I guess I can't blame the guy... but why park it in the back of a junkyard and not advertise it for sale?
So, I'm still trying to find a way to make it work. The Choke Cable idea didn't pan out.
Does anyone know if I can buy a similar cable and modify it to make it work?
on
I don't know how to modify one but have you tried a junk yard search?
https://findapartnow.com/
Car-Part.com--Used Auto Parts Market
I found 3 on carpart.com
But your suggestion did give me an idea. I know that I need to get a cable from a truck with Factory installed A/C that also has dual tanks. So, factory air is pretty easy to determine if there are enough pictures (Passenger vents look different on the dash panel... the climate control module has A/C... and dual tanks = two fuel doors).
So, if the pics have all of that, I can contact the yard directly and ask them to pull it/ship it.
I'll let you know how it goes, and thanks for the reminder.
I haven't searched on car-part.com for this particular part because I haven't found it listed specifically. I think the problem is that some people call it a Heater Cable (like me), but other people don't. Makes searching more challenging. I guess I just don't know what item to search for.... What did you search for to find your three results?
Some of the websites specifically ask for that piece of information as if it did matter. I guess it's like the parts store asking you what size engine you have when you need to buy freaking wiper blades.
That's also good to know. ...and that's the other frustrating thing... I don't have much exposure to other trucks behind the dash, so it sounded plausible to me (since there is a tank switch that also runs from the heater control unit).
My tank selector is by my knee . think the older trucks had it it by the heater control. If you were looking for the whole unit I could see an issue
Item #18518. That is only the base part # for any ford heater cable you will have to put your prefix in front of it. There are several websites that tell you how to get the full part # Unfortunately you are trying to find a part that has been discontinued and there is no aftermarket.
