C6 transmission fittings
Trying to replace the cooling lines on my C6 transmission and am running into some difficulty. The adapter fitting that goes into the transmission on the outlet is cracked. I need to replace it in order to replace the lines. From what I'm seeing the fitting is 1/4 MPT with a 5/16 inverted female flare on the receiving end. Is that correct? I've also noticed there are different style adapter fittings that have male ends to go onto the lines. Dies any have any advice on which adapter fittings would be best to replace the originals as I think I'm going to just replace both. Also does anyone know whether or not these fittings can just be unscrewed from the transmission case with out screwing up anything inside the transmission. Thanks
The following users liked this post:
Both fittings on the trans are the same: 87944-S8 .. Fitting ~ 1/2" -20 x 5/16" tube.
PREAUS MOTOR CO. in Farmerville LA has 22 = 318-368-3805.
GREEN SALES CO. in Cincinnati OH has 833 = 800-543-4959.
So the stock fittings that came out of my c6 were1/8 npt male to 5/16 inverted flare female. I replaced those. Both were cracked and one was leaking bad with tge other soon to follow I'm sure. After much deliberation I ran braided stainless hoses and used AN fitting in the transmission and radiator with matching AN female ends on the hoses I made. Thanks for all the advice.
C6 Cooler Fitting size
Im digging this thread up trying to figure out the size thread of the inlet and outlet cooler fittings on my C6, mind you its a 1968 and it looks like these fittings changed over the years ? I keep reading that the case input thread is 1/8npt, but thats not what I have here, it measures .50,.51,.49 depending on where you measure on the threads ? The flare fitting size is the 1/2-20. Im trying to go straight AN hose but cant figure out this size, its not a 1/2-20 or 1/2-13. I can get a M14-1.50 to thread on easily but its slightly to big as a 'bolt' fitting into the case... Any help is appreciated.
C6 Fitting
C6 Fitting
I think Ive answered my own question, if anyone else is trying to find the original case fitting size to a 60's C-6, im 98% sure its a 1/2"-18 UN/UNF thread .... and good luck finding any AN adapter fittings for that size, looks like I will just go into the fitting itself with the 1/2"-20 to AN6... Just didn't want an additional fitting to give me an additional leak someday...
Digging up this old thread but if someone else is looking for this fitting, I think you should know it is NOT 1/2-20 although it LOOKS like it is...it is super close.
I ran -AN6 to a filter, radiator, cooler, and back to transmission. The correct fitting is https://www.redhorseperformance.com/...ng-black-2pcs/
1/4 NPSM.
I originally sourced 1/8" because of several threads stated it was 1/8. Mine was definitely not 1/8. So I pulled it out and it looks just like a 1/2-20 oil drain plug thread, but when you try threading the old fitting into a 1/2-20 nut, it won't go at all.
Hopefully this helps someone down the road!!
1/4 NPSM.
F100-1969
17
10-18-2018 04:33 AM
smashclash
12-06-2010 06:16 PM
zap389
10-05-2008 09:39 PM
