Addressing the Rust - it's bad
Good afternoon Bump'rs
It's time... I need to address the rust issues.
Above the windshield on both sides of the cab, I have rust all the way through the outside sheetmetal.
The plan is to cut, flick, grind, whatever, loose metal off... apply a rust converter of some sort, put on some anti-corrosion primer, bondo it, apply some more primer, then paint.
Gurus... I bow to your guidance.
What's the best rust converter to start with on this issue?
If pics would help, let me know.
Thanks much
Thanks much
Right now, the truck is in San Diego.
Consider yourself in luck! There are tons of trucks out there that have clean cabs on them! It's much, much more difficult to find clean trucks here in the Midwest, or the east coast that are clean, too much salt exposure from the roads when it snows!
on
With that much rusted areas it would be cheaper to make it in to the first coverable for those warm fun summer days & nights cruising around. That's your only options.
Or like others have done replaced the cab if you don't have a welder or know anyone who can do the repair for you.
Now many times when a truck body is in this bad of shape, you'll find that the cab mounts our in need of replacing also. So you should do a good inspection on them and think about your next plan for this truck.
Also check the floor pans as those our another areas of needed replacing.
Sorry if, I have opened a can of worms for you but these our the areas a person should check before the buy a old ford truck.
Notice all the older guys who drive classics is there the only ones who can afford to fix them the correct ways. Not filling the body full of bondo!
Orich
Orich
