Won't start off key only pull start
Old 09-27-2016, 06:13 PM
daniel1997psd's Avatar
daniel1997psd
daniel1997psd is offline
here is a video of it cranking it has a new hpop ipr sensor also if you pull start it she will fire right up and run. Is this cranking to slow ? Also the clutch is grabbing a little.
Old 09-28-2016, 06:52 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
Originally Posted by daniel1997psd
https://youtu.be/VPE7uKD7joQ here is a video of it cranking it has a new hpop ipr sensor also if you pull start it she will fire right up and run. Is this cranking to slow ? Also the clutch is grabbing a little.
When you stop cranking, do you hear any gurgling in the engine? It could be air in system causing a hard start.
Old 09-28-2016, 08:15 AM
madpogue's Avatar
madpogue
madpogue is offline
RPM on the dash seem low to me.
Old 09-28-2016, 09:01 AM
daniel1997psd
where should the RPM be on dash when cranking?
Old 09-28-2016, 09:02 AM
daniel1997psd
no not that I can tell
Old 09-28-2016, 09:14 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Why are there three threads on this one issue. Stick to one, it makes it easier to follow what's going with your truck.
Old 09-29-2016, 06:52 AM
daniel1997psd
My bad not sure best way to use this.
Old 09-29-2016, 07:25 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Does it smoke while cranking?
It sounds like it's cranking fast enough, but the tack says it's not.
If the clutch is grabbing, try putting the tranny in neutral. That may allow it to spin faster using the starter.
Old 09-29-2016, 09:15 AM
daniel1997psd
No smoke and the oil pressure is high but the volt meter on the dash says the batteries are low. I did put it in neutral still nothing. I took the starter out to get tested and they said its fine
Old 09-29-2016, 09:35 AM
madpogue's Avatar
madpogue
madpogue is offline
The dash voltmeter tells you voltage, but nothing about the batteries' current capacity. It will always read low when you first turn the key to RUN because of the load of the glow plugs. You need to LOAD test the batteries, and make sure they're isolated when you test them.
Old 09-29-2016, 09:37 AM
CampSpringsJohn
I believe your voltage is too low while cranking for your injectors to fire. Try jump starting it. What happens while pull starting it, your voltage stays up so the computer sends the signal to fire the injectors.
Old 09-29-2016, 10:03 AM
daniel1997psd
ok do you know how many volts it needs. And is there a sensor or something?
Old 09-29-2016, 10:09 AM
CampSpringsJohn
Not right off I don't something around 10 though.
Old 09-29-2016, 10:27 AM
madpogue's Avatar
madpogue
madpogue is offline
The "sensor" is the PCM. It checks system voltage and RPM while cranking, and will only fire the injectors when they're both sufficient. Going from memory, it's 10.5 volts and 200 RPM.
Old 10-01-2016, 12:17 AM
79jasper's Avatar
79jasper
79jasper is offline
Also parts stores testing a starter means nothing.
Just because it spins doesn't mean it's good. May not have enough go juice inside, could be drawing too many amps, etc.
Batteries first.
Quick Reply: Won't start off key only pull start
