My 2017 Super Duty
The only sure thing is the OBDLink MX Bluetooth. It's not cheap but the lesser adapters have all been reported to fail or support far less changes and functions. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Have you used the OBDLink MX Bluetooth? I am always hesitant to try these types of things.
Yes, I changed my wheels and tires from the factory 18" size to the 20" size. So, I updated that to correct my speedo. I also enabled the DPF filter screen on my truck. That BT and Forscan are foolproof. It's all plain English settings in drop down menus. The 17 should have a lot more adjustable parameters to change if so desired just like the 150's. Can't wait for mine...
on
Yes, I changed my wheels and tires from the factory 18" size to the 20" size. So, I updated that to correct my speedo. I also enabled the DEF filter screen on my truck. That BT and Forscan are foolproof. It's all plain English settings in drop down menus. The 17 should have a lot more adjustable parameters to change if so desired just like the 150's. Can't wait for mine...
