Care and feeding of the 5R110W
Old 09-26-2016, 10:43 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
If you let your truck watch this you know what it will be asking for.
Sean <BR>
6.0L Tech Folder
Old 09-27-2016, 07:27 AM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,074 Likes on 1,404 Posts
Sounds like they've been listening to Mark for the last dozen years.
Old 09-27-2016, 08:35 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
My FYI $.02 worth. Bought my X in '05. Changed the fluid and filters at 30K miles with SP. At 60K miles I changed the fluid and filters again but replaced SP with Royal Purple Synthetic ATF. I also added a PML 4.5 quart larger aluminum pan. To date I have 135K on the X with the RP fluid and will change fluid at 100K. I also removed the little toilet paper filter. I run an X-4 tuner with the tranny set to "firm" shifts and an Atlas 80 FICM tune. The tranny shifts great with no hesitations. I also tow a 10K lbs. dump trailer and a 7K lbs. boat and have never experienced a bad shift. Again, just passing on my experience.
Ed
Old 09-27-2016, 11:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,573 Likes on 1,051 Posts
Why did you remove the filter? That doesn't sound like a good idea.
Old 09-27-2016, 03:20 PM
Amped's Avatar
Amped
Amped is offline
I have always drained and refilled with Mercon SP. Last time i tried to get it Ford dealer told me it was discontinued and i could only buy Mercon LV. I did not want to mix SP & LV so i was able to find it on amazon. Anyone mix the two?
ALso a side note, my transmission in my truck (2005 6.0 diesel) seems to have a rough shift into 2nd gear only sometimes, like a clunk. Any ideas? should i be getting it looked at? Has done it for a few years.
Old 09-27-2016, 04:17 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
MERCON SP seems to be back to stay for a bit longer. I have not had any
problems getting my hands on it at all.
Amped you may want to start a new thread so that people will see your question.
Sean <BR>
6.0L Tech Folder
Old 09-28-2016, 06:55 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
From what I have seen in the fluid pan (the black stuff) from previous changes the filter is not very efficient and as it gets dirty it presents an increased restriction to the fluid flow through the tranny cooler. I would rather have cooler fluid.
It is like an engine oil filter, it is not very efficient or the oil would remain clear until the next oil change and, as it gets dirty, it restricts oil flow. During high demands, the oil filter bypass valve opens and there is no filtration. I use a K&N reuseable oil filter to increase flow through the engine. Plus I run my RP engine oil 10K to 12K miles. I remove the K&N every 5K miles, check the magnets for particles or big chunks, clean it with gas and reinstall. It has worked great so far.
Doing those two things with filters has produced no tranny issues and I have never replaced a turbo or injector. I have an '03 motor in an '04 X.
Again my experience.
Ed
Old 09-28-2016, 07:30 AM
Mark Kovalsky
It's a bypass filter. Only 10% of the flow to the coolers goes through the filter.
It may not have produced any problems yet, but I expect you'll have failed solenoids because the bypass filter isn't removing the very fine particles in the fluid. These particles have been proven to make solenoids stick. Been there, done that.
Old 09-28-2016, 09:46 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
Mark, thanks for the info. I may reconsider. However, I would think using synthetic tranny fluid, tranny solenoid "stiction" would be significantly reduced or eliminated like injector "stiction" is with synthetic motor oil. Also, about a year ago, I added 22 oz. of AR9100 friction modifier to the tranny.
Ed
Old 09-28-2016, 10:09 AM
69cj's Avatar
69cj
69cj is offline
Ed
You're still going to get X amount of clutch material going through the system. Good luck, I think you will need it sooner than later. Manufacturers don't put in filters because they have too much money laying around. It's for a reason and that's to protect them during warranty and you later.
Old 09-28-2016, 10:38 AM
TooManyToys.
The problem isn't "stiction", it's debris catching between the spools and body. Archoil is a product to remove varnish and reduce friction. Having a 30 year career in designing and testing friction material, we design the friction material for the lubricant or fluid designated by the manufacturer. Anything else don't talk to me.
Old 09-28-2016, 10:50 AM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
DSMMH: You may want to contact the maker of your pan and see if you could also use the 6.4 trans filter -- it is a whole different animal than the one that came in our trans. Watch Jack's video on the 6.0 vs. 6.4 trans filter and I think you will get both that, and what others here are telling you about filtering the trans oil...
Old 09-28-2016, 09:03 PM
Mark Kovalsky
I don't see how synthetic helps the situation of fine particles in the fluid causing the solenoids to stick. In my experience (and I have A LOT of automatic transmission experience) synthetics are exactly as prone to particulate contamination as any other fluid. That's why it needs to be filtered.
Yet another thing I would never do to my transmission. What does that do to the clutch slip times? Have you measured that?
If it makes the fluid "slipperier" then the slip times get longer and the clutch life goes down. Plus you'll have more contamination in the fluid to help stick the solenoids.
If it makes it less "slipperier" (and I don't know what this friction modifier is supposed to do) then you'll get harsh shifts. Some of those could get harsh enough to break parts.
caseyodell
07-07-2015 03:29 PM
jim0528
1997 - 2003 F150
19
04-03-2009 12:13 PM
bowdog
1997 - 2003 F150
02-08-2008 03:12 PM
Ned Nimrod
1997 - 2003 F150
09-26-2007 01:35 PM
cajun1965
1997 - 2003 F150
07-31-2007 09:51 PM
Quick Reply: Care and feeding of the 5R110W
