Generator / Regulator Question
Truck is '53 f100 215 six positive ground. I've got a new voltage regulator which I polarized (disconnected FLD wire from generator at the regulator, touched it to BAT terminal on regulator for about two seconds & saw the blue spark), my generator has been bench tested and it is working right, and my battery is new and fully charged. At low idle, the dash gauge needle is right in the middle. It doesn't appear to move at higher rpms. When any juice is used, such as turn signals or headlights, the needle moves to the discharge side, and still doesn't move at higher rpms. I am not sure what to check for now. Should I expect the needle to be on the positive side at higher rpms? Should it stay over on the discharge side when I'm using the lights? Should I have to adjust a new regulator?
I'm running six volt positive ground. I measured the voltage at the battery with everything off and got 6.32 volts. When running at low rpm with nothing else using electricity, I got 6.18 volts. There is a 10 gauge wire between the voltage regulator and the generator. I will make sure that the inner fender (onto which the regulator is attached) is solidly grounded to the frame. Maybe that will make a difference.
No, I didn't try that. I'll see what readings I get at higher rpms. I am also going to make sure that there is a good ground connection between the regulator and the frame. The positive battery terminal is very well grounded to the frame with a heavy wide strap. I also have a ground strap between the frame and the engine and the frame and the cab. But, I do not have any straps between the frame and any front end sheetmetal. I'll install a couple. The ground may be the problem; I painted all the body pieces prior to assembly, and the ground between the regulator and frame could be weak. I have also noticed that my turn signals flash at a slower rate that I recall that they used to. This may also be ground related?
The big ground strap connected to the battery should really go to the engine or bellhousing, as the starter is by far the heaviest load. The engine is sitting on rubber mounts, not connected directly to the frame electrically. Nothing on the frame or body draws much power.
rustyranger390
10-05-2011 08:47 PM
SteV8e
11-14-2005 07:30 PM
