Hpop pressure no start
When your starting your 97,my hpop pressure guage hits 500 psi,truck should fire.now when it doesn't and your cranking within 2-5 seconds it jumps to 3000.
(Stock resealed hpop) BIG load on starter (new Napa 2001 update )
Sounds like it's loading up.got white smoke. Tach shows movement.
(NEW CPS navistar )
(New IDM napa)
(PCM swamps obd2 upgrade.)
It fires a little. Need a direction
(NEW CPS navistar )
(New IDM napa)
What condition are your glow plugs/GP relay? You are getting white smoke, so the injectors are firing. Have you tried starting after the engine block heater has been plugged in for a couple of hours? To me, it sounds like you are low on heat to get the engine to fire. A diesel needs fuel, which you are getting, compression, and heat in the cylinder to fire.
Ok ,checked glow relay voltage. Did not try to start. 1st test Hot side 13.20 press dash switch 11.20. 2nd test 12.70 hot activated 10.70.seem to be going down. Batteries have been on charge. 2 amp trickle.
Waiting for engine to he as t up. (Plugged in block heater,again)
how long did you hold it down for?
We were holding glow button down maybe 10 seconds. It fired up. However E fuel pump went to 80+lbs.and I shut down. Now it won't start again and I thru a 1661 code.glow plug relay was dropping 2+volts when cranking. Fuel pump stock 2002 pump into fuel bowl assembly should be 65 psi,right?
Strikeldr
29
09-18-2010 01:36 PM
njthorne
10-04-2005 06:01 PM
