Key in ignition beeping, with no key. Okay to cut wire?
Old 09-26-2016, 07:51 AM
Oldanvilyoungsmith's Avatar
Oldanvilyoungsmith
Oldanvilyoungsmith is offline
Okay, the "key in ignition" beep is constantly sounding if the truck is off, and the door open. Even with no key I'm the ignition. I had the steering column cover off to look at it, and found that if I disconnect this pink/black wire it stops.
Am I fine to just cut and tape off this wire? I don't really need the reminder, and the beeping is annoying when I'm working on the truck and have the door open. But I don't wanna just go snipping wires that might affect something else.
Old 09-26-2016, 08:04 AM
NTENSE's Avatar
NTENSE
NTENSE is offline
I wrapped mine with electrical tape and tucked it out of the way.
Old 09-26-2016, 08:18 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
I broke mine when I replaced the cylinder and it's just hanging there. No ding, ding, ding and no problems yet.
Old 09-26-2016, 08:32 AM
Oldanvilyoungsmith
So no side effects from disconnecting? Awesome. I'll probably just wrap it up to make sure it doesn't contact something and start dinging again. Man I'll be glad to have that noise gone.
Now I gotta figure out shutting off the seatbelt reminder that doesn't work. Not quite as annoying, but still... I read somewhere I can turn it off, I'm gonna try that today.
Old 09-26-2016, 11:29 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
Just press your seatbelt buckle button. Should turn it off
Old 09-27-2016, 05:32 AM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
If you use AE or similar to check codes it will give you a 'key in ignition circuit' code. Mines disconnected and i just ignore it.
For the seat belt minder see if this works for you
https://www.ford-trucks.com/forums/1...t-warning.html
Old 09-27-2016, 10:30 AM
Oldanvilyoungsmith
I haven't tried that method for the belt minder yet, but I tried the method outlined in the owners manual (basically the same, but it says to buckle and unbuckle 3 times, not 9). But then I just gave up and unplugged the wires under the seat... Still came on... Not sure what else to do then, lol. I'll try the method you posted later today when the wife gets back with the truck.
kalinks
2004 - 2008 F150
08-25-2018 10:46 PM
stbird
1999 to 2016 Super Duty
12-29-2017 11:46 AM
raysmyname
1997 - 2003 F150
08-27-2013 10:26 PM
herman391
1983 - 2012 Ranger & B-Series
05-27-2007 06:00 PM
ashleymc
2004 - 2008 F150
12-09-2005 05:54 PM
Quick Reply: Key in ignition beeping, with no key. Okay to cut wire?
