2005 Excursion lift block questions
For annual Utah safety check, I am being required to replace my three block 4" rear lift with a single 4" block. Does anyone know what taper if any is required, and what size pin it takes? Also, who might sell the least pricey blocks. Of course I already have the U-bolts. Thank you. (I bought it last year in Arizona, and the prior owner had the 3 block lift and no mud flaps. I installed flaps to pass, but the safety guy told me "I'll let you slide this year, but next year you'll have to have a single rear lift block)
v-10 with 37's
v-10 with 37's
Can you supply a picture? I only ask because the 4X4 EX came with a 2"-ish stock block and you are saying that you have 3 blocks equaling a total of 4", does it have 2 1" blocks, or is the perch on the axle being incorrectly counted as a block which sometimes happens.
I run the stock F-350 tapered blocks under my modded B codes and that has worked our well for me but I do not know the amount of taper/angle on those blocks.
Thank you for the replies.
The top block seems like it's the stock block, about 2" tall with a "bottom out stop" sticking out on the inboard side, then there are 2 @ 1" aluminum blocks sandwiched below that block and above the bracket that is stock welded to the axle. I can find 4" blocks, but they come in various tapers and pin sizes. I'm just trying to figure out what taper and pin size I'll need.
Thank you very much.
I used a non tapered 5 inch block that was actually 5 3/4 tall with the tang or bump stop ear. The guy who installed it stacked the old 2 and a half inch block on top. I asked him why when I picked the X up. He said the instructions said to do that.
The block was 3 inch wide and 7 inch long. Don't get the ones with a narrow width or length. The oem block is 3 wide and 7 long by 2.3 inch tall.
My X *** sits 45.6 tall verses the front at 42.6. Not really noticeable. I hung a 5000 rv on the back and it barely dropped the rear.
I don't think the long wheel base needs tapered blocks. You can get them but don't get those shims. Shims will slip out. The block I got was with a 5/8 pin and both blocks locked together so will not shift or slip.
I'm thinking of going with the 4 inch pro comp rear springs and the oem block in the future.
I'll post a couple a pics later
Edit to add: I was thinking of these when first researching a lift for the X. http://www.pmfsuspension.com/Ford-Fa...ocks_p_42.html
The Excursion doesn't have a long wheel-base. The short wheel-base of the F-series truck (which the Excursion matches), uses tapered blocks. The long wheel-base F-series trucks use a no-taper block for the MY's in question.
Stewart
Stewart
I am considering these: 4-inch Universal Rear Lift Blocks [6593] | Rough Country Suspension Systems®
And here's a pic of what I am trying to replace.
Does anyone foresee any problems before I commit to buy and install?
All I have ever owned was crew cab long beds
1. Those rough country blocks are only 2.5" wide and your springs are 3" wide.
2. looks like you will still have to stack blocks to stay at your current height.
Hard to say for sure but it looks like you have a total of 8+ inches of blocks.
Have you measured the total height of all the blocks ?
FWiw, The narrow one at the bottom looks like a tapered wedge.
I wasn't referring to the longest or shortest wheel base. Simply, the long wheel base of the excursion. But thanks for pointing that out
Since you have no vibration with the current set up, go with a 5 inch block 3 inches wide and 7 inches long with the tang bump stop.
Here is my non tapered set up which has almost no noticeable vibration other than on acceleration.
Here is the height of a 4 inch front lift with 7 inch in back. The back having 5 3/4 inch block with the oem 2.3 block stacked.
Hardly a rooster tail look.
