Ugh...1953 Frame Crack
Looking for some advice and sympathy! I'm neck deep in a frame off resto of a 53 and noticed a crack in my beautifully powder coated frame. Ugh...just my luck. I noticed this a while ago but thought it was just a powder drip. After further inspection from the other side of the frame I'm pretty sure it's a crack. Based on some searches this doesn't look like a common crack location on these frames. Fixing this would be pretty involved as part of the crack looks to be under the cab mount and the center engine crossmember brace. Fun times.
You'll notice it right along the pin to the right of the cab mount.
If the truck will not be loaded down to capacity on a regular basis, or sold as a concourse "as-new" show truck, I would just leave as is and enjoy the truck as much as you can. Inspect it every 2-3 months to see if it grows considerably. You can also drill out the exposed ends which stops the crack from growing, generally.
Howdy,
I don't think hese old truck frames were heat treated like modern trucks are. That particular spot doesn't appear in a structural area and probably won't hurt a thing.
If it were mine, the frame was bare, and I was going to install a stroked/balanced/bluprinted/turbocharged 460, I would probably remove the rivets, drill/weld and patch-plate it.
Here's some good stuff on truck frame welding/drilling etc......
Tips on truck frames
If I was going to run a stock 292 and just drive it, I would probably drill it and call it good!
Cheers,
Rick
Cheers,
Rick
Bigwin, you ever see this spot develop into something major? Fixing this down the road once the truck is done would be a huge pain however fixing it now would be a pain as well.
