1968 Turn Signal/brake issue
Which would be the nearest hot wire near the wires down there?
79 white red is hazard switch. I didn't use this one. I kept the hazard switch on my dash. You could easily wire the 79 column switch in if you like.
79 Blue/red is the indicator light. I didn't hook it up. If you want to hook it up, just splice in to your dash lights. No big deal.
79 yellow = ground for the horn. The 78/79 horn has two wires. The yellow is the ground, so ground it out.
79 dark Blue to 71 Blue yellow
79 light green to 71 light green
79 orange blue to 71 orange blue
79 light blue to 71 light blue
79 green white to 71 green white
79 green orange to 71 green orange
79 white blue to 71 white blue
In the above wiring schematic you will see the T/S switch towards the bottom on the right side. 6 wires going to it and to it's dash wiring plug. Each of these wires are marked on this schematic with a circuit number. The left side of the schematic lists what color the wires are in the circuits.
A 72 T/S switch is different from a 68 switch. Your dash connector would be different than a 72 switch. Try mating up the colors below that I got from the site ultraranger posted above in post #9.
I was digging deeper today and think i found some more issues. I was checking to see what wires from the harness has power. Appears that only the horn is getting power. I checked all the fuses and those are fine and I even replaced the flasher signal flashers (They were rusted and not receiving any power). I check to see what power was running to the cluster and seems like there is only one wire that is receiving power in the harness which is a green-red wire 904 ( http://www.fordification.com/tech/wiring/68-09.jpg)... My gauge lights are working so im guessing this wire is sending power to the lights.
So im only getting power to the horn wire on the column harness and only power to the green-red wire #904
Popped the hood and looked at the wires running threw the fire wall and noticed that these two wires are unplugged... ive tried looking online and cannot find what the wires are and where they run.. could this be the power issue inside the cab?
Yeah it appears that it originally came with a three speed on the tree and the automatic conversion was made and he swapped in this 73-79 column. What would you think the issue with power to only the horn wire and the green-red wire in the cluster?
Do you have the ignition switch to "ON" when you tested for power? Remember, the key has to be on to use the T/S.
#29
So. Now after mating everything up and checking wires again. Only my front right turn signal will work and when I turn it on both tail lights flash. The front left turn signal does not work but when It on both tail lights flash. Also ony the left rear light comes on with the headlights but both rear lights work when I press the brakes... and ideas anyone?
#30
