Missed Connections
Missed Connections
Can y'all help me figure out where these vacuum amd electrical connections go? It's a 1983 F100. Thank you.
Looks to be some kind of solenoid.
I believe thhe green vacuum line is connected to the EGR valve.
A wire that seems to be loose and comes from an engine accessory below the smog pump.
That looks like the connection to the electric choke cap. Put a voltmeter on it first with 'key on' and second while the engine is running.
Thank you so much. The truck would not want to idle. In the past, my grandfather held the choke open with a steel clip and fed it gas until it warmed up.
James Wagoner
18
05-19-2018 12:11 AM
Jtay561
13
02-12-2015 05:01 PM
