Truck wont start (starter problem)
Old 09-24-2016, 05:14 PM
epoppe4's Avatar
epoppe4
epoppe4 is offline
Guys i have a weird problem. My 2001 Ford Excursion will crank over but wont start. Basically the truck cranks over but seems like its not getting enough juice to start. so i think the batteries are low got them fully charge and same problem. But as soon as i jump the truck with my wife tdi passat starts right up. So i check the voltage at the starter solenoid and im getting 12v. so i think its something wrong with the starter itself. Took it to a rebuild shop and they said its good and has no issues. So now i am back to square 1. any ideas of where to start will be helpful. Truck has no check engine light on.
i honestly think its the starter and want to replace it but the 3 bolt good starter is 200.
Old 09-24-2016, 06:12 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
First, suggest you get your Batteries LOAD TESTED to determine their health. Second, once you know your Batteries condition and move forward, do a simple Voltage Drop Test to determine if the issue is the Starter, Solenoid, or Wiring.
BuckYoung
12-21-2015 07:37 PM
Tyler S
27
06-19-2015 09:09 AM
TRUCKINGFORDEVER
1999 to 2016 Super Duty
01-16-2011 10:53 PM
IDPisan
10-06-2009 01:43 PM
putter53
1997 - 2003 F150
12-15-2007 02:56 PM
Quick Reply: Truck wont start (starter problem)
