1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Sensor leveling arm
Old 09-24-2016, 01:06 PM
mikemrq's Avatar
mikemrq
mikemrq is offline
Sensor leveling arm
Have a 2006 Navigator. I bought a 3" spacer kit. The spacers are 1 1/2", was told that they will give 3" lift. I'm going to make my leveling arms longer. My question is, how long do I make my arms? 1 1/2" or 3"?
Old 09-24-2016, 01:29 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
You'll have to get some material and fabricate an extension.
Old 09-24-2016, 01:30 PM
mikemrq's Avatar
mikemrq
mikemrq is offline
I know that
Old 09-24-2016, 09:26 PM
mikemrq's Avatar
mikemrq
mikemrq is offline
The question is how long?
Old 09-25-2016, 10:15 AM
alloro's Avatar
alloro
alloro is offline
The same amount you lifted the truck. If it's 3" then the rod has to also be extended this same 3". This might not be your exact sensor but the idea is the same for all.
Old 09-25-2016, 10:19 AM
mikemrq's Avatar
mikemrq
mikemrq is offline
Even though the spacers are 1.5" the rods should be 3"?
Old 09-25-2016, 11:33 PM
alloro's Avatar
alloro
alloro is offline
No, I said you extend it the same amount you lift the truck. If you lift it 1-1/2" then extend it the rod 1-1/2". If you raise it 3" then extend the rod 3". I see no way you can use a 1-1/2" spacer and get 3" of lift out of it unless you're stacking the two 1-1/2" spacers. But if you do have some way to make the 1-1/2" spacers lift the truck 3" then the rod should be extended 3".
Old 09-26-2016, 09:42 AM
mikemrq's Avatar
mikemrq
mikemrq is offline
It's a spacer from CTS. They said that the spacer is 1.5" and will lift my Navigator 3" because of the geometry of the suspension. Anyone else hear of this?
Old 09-26-2016, 02:04 PM
alloro's Avatar
alloro
alloro is offline
That would depend on where the spacer gets inserted. If for example the 1-1/2" spacer is positioned halfway out from the suspension pivot point like shown in this simple drawing, you will end up with 3" of lift at the end.
Old 09-26-2016, 02:08 PM
mikemrq's Avatar
mikemrq
mikemrq is offline
Actually it's going on top of the air bags.
Old 09-26-2016, 05:17 PM
alloro's Avatar
alloro
alloro is offline
Then all you're basically doing is making the airbags 1-1/2" taller. You will only get 1-1/2" of lift and even then it will only happen after the extension modification to the sensor rod. The sensor works by measuring the distance between the unsprung suspension (on the ground) and the sprung suspension (the body). So just adding the spacers will have no affect on that distance.
Jonnyuma
09-16-2016 08:44 AM
Mikes92F250
03-13-2012 10:37 PM
ganzey
1999 to 2016 Super Duty
02-05-2011 12:15 AM
autiger1102
Aftermarket Products
12-05-2009 10:05 PM
summitx670
12-16-2008 05:43 PM
Quick Reply: Sensor leveling arm
