Are you getting a 1/2" of deflection on the belt when tightening? Meaning with a straightedge across the pulleys, can you only press down a 1/2" and no more. You don't want to go tighter than a 1/2".
The bolts that hold things together are slipping. With quality belts as you stated, the belts are not the problem.
Pluck bolts, put in lockwashers, tighten to the proper deflection.
