Possible bad PSOM or speed sensor?? - Ford Truck Enthusiasts Forums
Old 01-06-2002, 07:23 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is gaining momentum as a positive member of FTE.
Post Possible bad PSOM or speed sensor??
Hi,
Just signed up, it looks like some people here really know there stuff. Here's my problem:
1) Speedo jumps around erratically.
2) Cruise control won't lock on a speed, it wants to hunt around.
3) Tranny shifts into 2nd hard, occasionally comes out of OD at highway speeds.
4) ABS light is on on dash.
Is the PSOM or the speed sensor bad?
Does anything else sound like it is bad or needs attention?
Any help would be appreciated!!
Thanks in advance,
John B.
Old 01-06-2002, 11:28 PM
beratte beratte is offline
beratte is starting off with a positive reputation.
Definetly sounds like the PSOM, I think this TSB is exactly the problem your having.
Programmable Speedometer/Odometer Module- Pointer Waver-Service Tip
Article Number 96-21-11
LIGHT TRUCK:
1992-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES
ISSUE:
The speedometer needle may waver and/or a light surge may occur on some vehicles when speed control is used at highway speeds between 80-113 km/h (50-70 mph). This may be due to slight dents/chips in either the exciter ring or the Vehicle Speed Sensor (VSS) and air gaps between the VSS and the exciter ring.
ACTION:
Replace the Programmable Speedometer/Odometer Module (PSOM) if required. New PSOM's come with increased immunity to system variability. Refer to the following Diagnostic Procedure for details.
DIAGNOSTIC PROCEDURE
BRONCO/F-SERIES - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 F-Series/Bronco Body/Chassis Service Manual, Pages 13-01-30 through 13-01-32 and Pinpoint "B" of the 1996 Powertrain/Drivetrain Service Manual, Page 10-03-11.
ECONOLINE - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 Econoline Body/Chassis Service Manual, Pages 13-01-29 through 13-01-31 and Pinpoint "B" of the 1996 Powertrain/Drivetrain Service Manual, Page 10-03-9.
AEROSTAR - Perform normal PSOM diagnostics per Pinpoint Test "K" of the 1994 Aerostar Body/Chassis Service Manual, Page 13-01B-31.
1. Any slight dents, chips, etc., in either the exciter ring or VSS will create needle waver. Measure air gap between the VSS and exciter ring. It should be 0.38-0.51mm (0.015-0.020").
2. Check exciter ring runout per the same ring gear backface runout procedure of the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-00. Make sure the exciter ring is mounted correctly to the ring gear. If runout is more than 0.1mm (0.004"), perform the differential runout check per the procedure in the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-02A or 05-02D, to find cause and repair as needed.
3. If all items listed above check good, replace the Instrument Cluster Assembly. Obtain the correct service part number from the Parts Catalogue and then contact the Electronic Odometer Exchange Center at (800) 259-9700 for U.S. Dealers and (800) 663-9974 for Canadian Dealers.
NOTE:
DEALERSHIP MUST TELL THE ODOMETER EXCHANGE CENTER THAT YOU NEED A PSOM3 LEVEL CLUSTER FOR A SPEEDOMETER NEEDLE WAVER CONCERN.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
LABOR ALLOWANCE
DEALER CODING
OASIS CODES: 204000, 204100, 204200, 205000
Old 01-06-2002, 11:32 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
It could be a ton of different things. First off, how many miles on the truck? And it does have the 8.8" rear end, Correct? If so i'd pull your rear diff cover off and slowly spin the drive shaft by hand, Bolted to the carrier there is a speed sensing ring which runs the abs and your speedometer(your cruise runs off your speedo). The 8.8 rear end that you most likely has a tendency to go out. What can happen is that if metal pieces start breaking up and getting at that speed sensing ring it'll get the little teeth bent which sends a bad signal to your speedo, which in turn screws with both your abs and cruise. And it'll also send that screwed up signal to your tranny and cause shift problems. I know this cause what your describing happened to me about two monthes ago. I threw a speed sensor in, checked all the wiring, and almost ordered a gauge cluster and computer before my rear end locked up,,,,i figured it out when that happened. My spider gears were completely ground to nothing. As far as i could figure a piece from one of the clutch packs in the Trak-loc busted off and lodged itself between the sensor ring and the housing. One tooth was bent about a 1/16 of an inch different than the rest, but it was enough to set it off. The sensor ring was really cheap at the dealership, it was only like 20 bucks. Unfortunetly if this is the problem most likely you'll be looking at 50-600 dollars for a complete rear end rebuild. So the first thing i'd try would be to drain the rear end and check that. And even if thats not what it is, changing your diff fluid can't hurt. You can try to change that sensor on top of the housing, its about 15 bucks. Hope its the later. If you have any questions feel free to email me at Ryan50hrl(No Email Addresses In Posts!) If you do end up needing parts i have a bunch of stuff that might work for you. Gook luck
Old 01-06-2002, 11:50 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Old 09-06-2010, 08:25 PM
MIKE8349 MIKE8349 is offline
MIKE8349 is starting off with a positive reputation.
If you ever need a PSOM rebuilt, look up southern speedometer in Clearwater, Fl -
Mine went out and they fixed it for $145 and I had it back in the next day.
Old 08-24-2012, 12:28 AM
lindboep lindboep is offline
lindboep is starting off with a positive reputation.
PSOM Sensor
I am having the same problem on my 96 F-250....
Speedometer is bouncing
The odometer works only sometimes
ABS light is on
Check engine light flickers..
Someone said it was the PSOM sensor......Where is that located at on the truck?
Old 08-24-2012, 11:22 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
ABS light is on
Post#6 in this thread: http://www.ford-trucks.com/forums/10...ng-engine.html
But it is not causing your ABS light on issue......
Old 08-24-2012, 12:26 PM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
I'd double check the "ground system" for the PSOM first.
I "think" the ground for your psom is located on the firewall in the engine compartment, passenger side, up high.
That ground also has to be grounded to the fender as well as a ground wire from the battery to the fender.
At least that's how my 94' is if I remember correctly.
Any loss of ground in those places will "unground" (open circuit) the psom.
Also, check that fuse #8 and fuse #16 are seated into the fuse holder (in the cab) snugly. A loose fuse in a fuse holder will cause intermittant power.
My thoughts, maybe I'm correct,
Bob
Last edited by Truckin Bob; 08-24-2012 at 02:07 PM. Reason: correct information given
Old 08-24-2012, 01:53 PM
Ok so I was also told to check the VSS sensor. Where is that? Also where is the actual psom located on the truck?
Old 08-24-2012, 02:03 PM
rla2005's Avatar
The PSOM is attached to the back side of the instrument cluster. There is a photo in Post#6 of this thread: http://www.ford-trucks.com/forums/10...ng-engine.html
The Vehicle Speed Sensor (VSS) is located on top of the rear axle center section:
PSOM and VSS info here: Steve83 PSOM and VSS info
Be sure to check the codes that are causing your Check Engine Light to flicker on/off. There is a code for missing or erratic VSS pulses.
Old 08-24-2012, 04:09 PM
So I found out today that the cruise control does work BUT only when the sooedometer is boucing. Check best. It looked fine
Old 08-24-2012, 04:11 PM
So I fou out today that the cruise control does work BUT only when the sooedometer is boucing. Checked vss.It looked fine. Also tried to get advance to run codes but no computer hookup? Where is it located?
Old 08-24-2012, 04:37 PM
rla2005's Avatar
The Diagnostic Link is located on the driver side inner fender, near the hood hinge:
You can check for codes yourself by following this: Fuel Injection Technical Library How To Run a Self-Test
How did you "check" the VSS? You need a meter to check the output. One of the links I sent earlier has a procedure for doing this.
Old 08-24-2012, 09:50 PM
Ok i take that back i check the wires....i have a digital multimeter...can i use that to check it? if so how do i do it?
I noticed it is not shifting into the last gear...no overdrive, but when im going down a hill if i shift it into neutral then back in drive the goes in a higher gear but immediately shifts back down one....also i noticed it backfires and the engine rpm is very high even when i let off the gas going down the road at 50 mph
cruise control works when the speedometer is bouncing as well as the odo works when speedometer is bouncing
Old 08-24-2012, 11:01 PM
rla2005's Avatar
In the link I posted in Post#10 there is a drawing of the VSS/Speedo circuit as well as a test procedure. The instructions have you place the DVM on the input to the PSOM.
Random VSS / PSOM code - '95 F150 erupert66 1987 - 1996 F150 & Larger F-Series Trucks 12 10-04-2013 05:19 PM
E4OD Tranny Help/Advice Needed ride_gnu 1987 - 1996 F150 & Larger F-Series Trucks 20 01-03-2012 11:54 PM
95 F150 hard shifting and erratic speedo BRay09 1987 - 1996 F150 & Larger F-Series Trucks 23 07-06-2011 10:15 PM
Bad PSOM, transmission, or both??? dharget 1987 - 1996 F150 & Larger F-Series Trucks 7 11-06-2005 01:04 AM
Reprogramming PSOM improves performace? muckypaws 1978 - 1996 Big Bronco 7 04-18-2005 05:18 PM
Tags
1996, 2001, diagnostics, econoline, f150, f250, ford, odometer, psom, sensor, speed, speedometer, truck, vehicle, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
